After updating my SP to JB 4.3, every call I get is routed to the speaker when I answer the call? I have tried searching for everything in the settings, but can't find out what the problem is. It is annoying at work when I have to answer a call, suddenly the speaker comes alive when I swipe the green answer bar.
Any help is appreciated.
didn't try to uninstall updates for chrome.
i just switch to dolphin browser and fell better for my needs
LAG during answering remains. The phone keeps ringing for 2-3 seconds AFTER I've answered the call (ie. slid the green handle to right) and connects after the lag.
But this is another problem. It begun after Android 4.3 update.
that's right!!!
I havn't still update to 4.3 and my phone starts to use loudspeaker when I call someone just from two days ago! I disable chrome and it works!
Thanks to you and to @fedebt that hit me for first about that!
Anytime redbear76
This Bug is present in the 4.1.2 so it's not the 4.3 update at fault.
Don't know about that if you disable Chrome will do it. Has anyone tryed without restarting?
I know that I restarted and it would answer fine... for a day or 2 then back to Speaker.
Will try to also disable Chrome, I like Opera better anyways but I am not positive that it will solve it for good.
Just remove the updates for chrome,do not disable it yet.
How long would we have to wait till Chrome fixes this? Any idea?
I have no idea.Sorry.
@TwiCS wrote:
Can you please let me know how to disable Chrome ??? Thanks
Settings -> Apps -> Chrome -> disable
