From last few days I am not able to access my calender. Each time I open it shows "Calender is unfortunately stopped" Why did it happen? Does anyone has solution for it. I have Sony xperia J
Regards
jain
Make sure that the calendar applications have not been disabled via the app menu.
Settings > App's > All > Scroll to the bottom and check if you have any disabled app's.
If not you may want to try clearing data for your calendar app's (but remember that locally stored meetings may be deleted when doing this).
thnks a ton..it has started working now..:)
