I can't switch on my C510, soon after I switch it off. Phone won't turn on, if at all I press hold the button until 15-20secs after switching it off. Is this same with every C510? I have this question because, the phone is like this from the day i bought the phone. I had tried software update, it solved some problem with 'manage messages' :smileyhappy:, not this one.
There isn't necessarily anything wrong with your phone, as 15-20 secs to restart (if that's what you're saying?)sounds quite normal.However, if you still think it's too slow to start, you can try a master reset and see if that helps.
