When i try to pair my Desktop and my Xperia Active vía Bluetooth, i always get two different pairing codes (i'm using the assistant from windows 7 64bits) on the screen of my Active it shows a code, and my PC shows another completly different, no matter how many times i tried, is always the same, and is imposible for me to connect my smartphone to my PC. Is there any solution? Please help. Thanks
I've searched a simillar problem woth yours, I think they do not really work ( pc-phone via external dongle).. I'll try to see if I can search more of I have free time.
initiate the paring only on one side, the phone or the pc. first
open both device's bluetooth
my active usually initiates the paring first. make your phone discoverable
how about the good old usb connection?
Well i would like to use my bluetooth conection, rigth? SO, i tried everithing, but the codes are always different, and the pairing does not complete... Thaks anyway,any other sugestion? I've tried conecting the PC to the phone, the phone to the PC and same result the codes are always diferent.
I guess you could
can't you disable the pc's search and pair? just let it sit turned on. or try turning one device first before the other to let the other one discover the device first.
Usb connection work. i just want to pair my phone to my pc using my bluetooth... help please, the issue is that all the time, the pairing codes from my PC and my Active, are diferent.
It sounds like you're initiating the pairing from both devices.
Can you describe, step by step, how you are doing this?
The correct way to do this may differ as the Bluetooth software in computers can vary in looks and features.
What do you think about this forum? Let us know by doing this short survey.
No, i haven't.
Step by step. First I show how I have configured the bluetooth on my pc:
Aborve, my Bluetooth devise connectec to my PC
Adove, my active Bluetooth configuration, always visible to any Bluetooth devise
My OS is Seven Ultimate x64 and the Bluetooth is configurated under default settings (changing all of then doesn't make any diffference)
Starting Pairing
and then, the F..... problem (i've change the devise to every USB port aviable on my PC, start pairing from my PC, from my phone, EVERY, any possibility and always the same result...
and
This is my problem, always the same, no matter what, the codes all different. Please help. I want to deactivate those f...... pairing codes from my phone.
I see, here's how I do it.
open my PC bluetooth
next, Open my Xperia Active Bluetooth
I click on my pc and pair
on my PC
I click pair on both devices, and DONE!!
And that program "Bluetooth manager" is from Windows? or from your Bluetooth devise (do you use a laptop?), and also your Active is on Gigerbread, I'm on Seven and my Active have the latest update (ICS), and i repeat, I've done EVERITHING, EVERY POSSIBLE CONFIGURATION, and always the same result, pairing codes are different all the time, is there any Bluetooth manager for seven? or maybe my bluetooth devise (did you see it?) sucks... Thanks anyway noiramlb, I know you are traying to help...
