i have recently sent a mixture of pics and vids from my old phone. they have been saved in a bluetooth file in my gallery folder ( picks and vids in one folder / same vids in video gallery folder) how do i go about moving these files into new seperate folders.
im sure there is an obvious answer but after a monday at work and 30 mins trying to figure it out my self i just want some1 to tell me....
either mount your SD card to a computer and create folders and move the files around
OR
use OI File Manager to do the same on your Play
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
also check this app
Bluetooth file transfer
https://market.android.com/details?id=it.medieval.blueftp&feature=search_result
OR
also check this app
