Hello !
The battery on my xperia pro happens to drain out suddenly. It look like I have enough battery left, say 60 to 70 %, then all of a sudden, I get a sound alert, saying there is only 1% left and the phone goes out immediately. It is really a problem when I am in the middle of a call, a download or taking photos.
But, when I connect the phone to charge the battery, it is displayed immediately that there is 65 % left and not zero or 1%.
It looks like the software managing the battery is at default. I have tried to mend the problem with a battery calibrator application. But it takes a long time to mend it, when it does, which is not every time. And the problem will comme back the following week ...
What can I do ?
Thanks for your answer
Katryne
Consider that your battery is defective - You may have a high percentage as it's reading a certain portion of your battery then when it gets below a certain level it will switch to the next portion which may be defective and can't hold a charge hence the rapid drop is battery percentage
Thank you. Maybe I will look for a new battery ... or a new phone.
i have a problem with my sony xperia neo l mt25i
when i connect the phone to wall socket charger the phones battery keeps on discharging
