I bought xperia sola on 3rd June...
The battery lasts for only 5-6 hours with minimal use...this is irritataing !!!
any advice ???
D3xt3r Gave a very good suggesstion above, this is how to repair your phone
________________________________________________________________
Backup everything as it will erase all data on phone (sms, contacts,apps)
Update/Repair your phone via PCC
PCC (PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to).
Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
PC Companion http://www.sonymobile.com/global-en/tools/pc-companion/
After Reinstalling explore these threads
You could try a repair with PC Companion and a full reset first , or an upgrade if it is available. Apparently there are some bugs that get fixed this way.
Define minimal use fpr you. For me there is 4-5 calls per day lasting 2-3 minutes, and after that no activity on the phone. This way it lasts allmost 3 days.
really the battery performance is very bad,what do I do??
First, read the threads Nabeel recommended please. Also, try to disable Live Wallpaper and change it with a classic static one. At night , try and use the power saver feature and leave only the phone part active and disable everything else. I did this, and for now , the phone uses about 3-4% per night ( 7-8 hours) while not in use
