Greetings. Although there are few battery threads, I thought my question justifies opening a new one. I bought this beauty new 2 weeks ago and while I am generaly satisfied it seems to me that battery life is too weak. Definitely not in accordance to battery life test from reviews. Long story short, I would like someone to enlighten me if this is normal drain rate.
That's normal, as you can see the battery drained quite a bit while you were using the phone, screen on, wifi on.
@uliwooly
Many thanks.
