after i update my xperia p ics to jb my battery life got drain fast...plsss give a tip to avoid this thing..Now i have to charge it 3 times a day.thank you.
Repairing usually fixes these kind of problems,maybe a not proper installation of software causes this drainage for you.After repairing,also make a factory settings reset.
Repair phone software with SUS or PCC.Are you a heavy user?
Does repairing will solve the problem for sure??? yes um using it heavily, but even playing games for 20 minutes will drain 25% of battery it self,
please can you give me proper advice to solve this....,
Thanks for your advice alexdon,
i repaired through sony pcc and now the mobile working perfectly.
thanks for your help man, appreciate it....,
