I bought arc s 2 weeks ago. And now I have just realized that down the side with the headphone jack there is a gap between the metal border and the edge of the battery cover. Does anyone has this prb as well. What should I do? I haven't any other prb with this phn but only this cover prb makes me worried! any suggestion?
Hahah! Just had to suggest, why not create one thread for this and just paste the link to every post your reply in even if it doesn't seem that much connected with the topic. It would be easier and less space consuming. Peace.
done that before, and then I get asked over and over to explain this and that, so this is easier
