I'm trying to back up some things (contacts and calls, sms, settings, whatsapp and some line chats) with PC Companion copy and restore but it goes very slow, why? Another option? Any help?
I want to do it because battery drops very fast and last weeks hasnt't work very well.
Thanks
Try this instead
Alternatives on How to backup Xperias
I had the surprise that the OS was directly the last one.
I lost sms, notes, calls, WhatsApp conversations, some Line conversations I had also saved (both folders disapear from my device). Both ticks were marked. What a shame! ><
How did you performed the backup?
I understand but which method, bc I have myriad ways to backup
Going to settings, isn't automatic? Line keeping chats and WhatsApp Databases folder
I haven't used PCC
