Guys i have a problem !
Before update I did a backup of one application with Backup&store preinstalled app to SD card
After update when a try to make a restore of that app using the new Backup&store from Sony a receive the message that restore can not be realised because there is a different android version
What should i do now?
Is there an app which can restore these kind of backup's ?
Thanks
You need to move it to your computer.Check out this topic:
If you had the backup file you could have done something,but like that I do not think you can.I always advice people to backup using either PC companion,or for contacts,messages etc myphone explorer.
No problem,I do it for free.My pleasure is to help others.:smileytongue:
Well,that might be hardware issue,you should visit a sony centre for a quick check.
