with my Xperia SP, over the last couple of years, I have ended up having installed in the background (mainly though prompting/synchronising with their dersktop equivalents) Avast mobile security, CM Security, Malwarebytes Anti-Malware and Advanced Mobile Care (I also have CCleaner but am not sure if that is background resident). Hence I was wondering, as the phone's memory management is "challenging" anyway, which single (or more than one) package could I leave in the background, i.e. which is the best mobile package? thanks
That's an overkill, all those apps are using up your battery, RAM and Internal Storage, just pick one, I think @Thommo suggest users Avast.
