After missed or droped call phone automatically change ringtone mode to "only vibration". Use the phone about 3 days. System version 4.1.2. Installation of profiles managing program (Sound Profile) don't help((
PS
Same problem on Xperia P (here)
I think I found of problem source - it's my antiviral application - COMODO Mobile Security - it's last update. At some other (samsung) forums people talk about AVG, that causes just about the same behavior.
uninstall any of this apps
taskillers
task managers
antivirus
ram apps
battery apps
booster apps
and check again
