Hi
Mine is an Arc S LT18 model when i connect it to PCC it is saying there is a s/w update available when i check, it is from 4.1.A.562 to 4.1.B.0.431.but if start updating it's struck in prepairing computer for software update. please tell me a solution to upgrade my phone
Thanks
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
________________________________________________________________
or
Updated successfully. Thank you Nabeel for quick support.
Regards,
Shijith
