How to move those apps which are always stored in the internal memory to the sd card after gaining root access?
yes, done that. Ofcourse performance has improved drastically.
are you using GB or ICS now?
ICS. Tell me some ways to remove bloatwares...
go to settings > apps > all > tap on an app > disable
Does anyone idea about the new Xperia Smart Connect app that will hit Google Play from Mid- Sept. This app will be pre-installed in Xperia V and will be available as support for all Android devices with ICS 4.0 and plus.http://www.androidust.com/explore-sonys-new-xperia-app-from-mid-september/
