Hi sir, just a suggestion or query. Do anybody have a list of apps that is isntalled directly in SD? BECAuse somme apps only works if installe din phone. & cannot or may not work even transferred thru app2sd.
I think this would help a lot in deciding apps to install so that it may not affect the phone memory that much
thanks
ok really many thanks sir...
anytime, make sure that you restart your phone after rooting so it will work otherwise it wont
