I have connected my mini pro succesfully to a Nokia BH-105 Bluetooth headset. Both my phone and my headset are fully charged.
When I answer the incoming call, mostly the call gets connected through bluetooth headset, and it is also indicated in the screen
as follows:
Normal Scenario:-
However, quite often, it does not establish the actual connection and i dont get the audio transfered to my headset.
In such scenarios, The Bluetooth Bar is not underligned in green, but in bluetooth settings page it still shows as connected to phone audio.
Manually tapping the Bluetooth bar to switch it on doesnt work. Only option is to toggle bluetooth on-off and restart the headset and reconnect
Failed Connection State:-
Does any one of you have this issue.. Can anybody help??
This could simply be a Bluetooth profile incompatibility issue. However you can also try a software update on the phone and also reset the headset and perform the pairing again once you have updated.
