Hello Frnds,
Recently I saw this problem with my arc that the android market is not opening at all. It shows message as 'Loading' but it never loads. I tried it with GPRS & WIFi but it is not working.. I also updated arc to stock again with SEUS n thought the problem will be solved but it is not...
Please help me...
u downgraded ur software or repaired it ???
if u r currently having the stock version then update ur phone
few other things to check
settings>account and sync>enable background data traffic
also clear data of android market
settings> applications>manage applications>all>android market> clear data
then try opening it
then try opening it
how about
go to settings -> applications -> manage applications -> all -> market -> clear cache
is your internet working? open your browser and go to your gmail (not the gmail app, but on your browser log in to your gmail) does it work?
Thanks guys it is working fine now..
Excellent
