Hi all, I upgraded my X-Ray to Android 4 3 days ago and my games like "Shadowgun" "Dead Space" or my radio application "Stream Furious" Don´t work.
Also VERY IMPORTANT. I took some pictures with my phone and when in Media Go it does not detect them, nothing comes up, but there are pictures on my hone. I have uninstalled PC Companion and all and re-installed but there is NO CHANGE!
Please Help.
Thanks.
Yes, the games do work fine (they are compatible with Andr. 4) all I had to do was to restart the games. To start from the beginning, so it´s all working fine.
Hi
First, Some Games and applications aren't compatible to Android 4.0 ,yet. Be patient for an update by the developers.
Your second problem is strange. Actually it schould work. Do you have the latest version of Media Go and PC Companion?. If yes, I would suggest you to transfer them via Bluetooth or W-Lan , if it will be possible. ^^
