hello...i've bought this acro s in early september...did the phone has :
#1 SCRATCH RESISTANT REALLY?because it did not! my acro s already have few scratches that have been eyesore to me when I look at the screen...OR DID SONY ALREADY TINTED THE SCREEN? IF YES CAN I REMOVE THE TINT?
#2 WET FINGER TRACKING REALLY?because I think not! when it has water on top of the screen...the phone become crazy... suddenly it do whatever itself...open app drawer itself...etc... DO I MUST SEND THIS PHONE TO CLAIM WARRANTY BECAUSE ITS HARDWARE FAILURE?
#3 CANT MAKE VIDEO RECORDING UNDERRWATER AS ITS PROMO VIDEO IN ACRO S ITSELF (refer to num 2 problem)...
thanks alot nolramlb ive succeed in how to record video underwater...extraordinary performance! tq 4 u all...
enjoy, plese be reminded that if you are going to use your phone in any wet situations, make sure the phone is "cooled down" or not used moderately, as heat inside the phone can cause moisture to build up on the camera lens, if this happens just let the phone rest for awhile until the moisture subsides.
