hi frnds i had an issue while i m trying to use the option of sending the contacts as an message it automatically geting converted in to mms. so how to send them as sms rather than mms
you can't control that with the stock messaging app, you need to install a third party app like handcent SMS
thank you for your answer
Anytime
