Will Xperia Arc will automatic update the new version of Android Market:
http://googlemobile.blogspot.com/2011/07/new-android-market-for-phones-with.html
or just update manually.
it's supposed to be rolled out by google so you will get it, just like the last update, but if you can't or don't want to wait you can get it here
Good, so I try update manual.
yourwelcome, enjoy
