the upgrade for ST15i has started. but only for this build number 4.1.B.0.431.
what about my build number 4.0.2.A.0.62. ? can anyone explainl about this?
or maybe my build number wouldn't get the upgrade.
i'm sorry for my english.
of course I can, the best way to show is when the firmwares were released
keep in mind that the .42 .58 .62 and .69 are pretty much the same
http://www.ptcrb.com/vendor/complete/view_complete_request_guest.cfm?modelid=19513
| HW Version | SW Version | Request Type | Date Certified |
| A | 4.0.2.A.0.69 | ECO | Feb 27, 2012 |
| A | 4.0.2.A.0.62 | ECO | Dec 20, 2011 |
| A | 4.0.2.A.0.61 | ECO | Dec 12, 2011 |
| A | 4.0.2.A.0.58 | ECO | Oct 21, 2011 |
| A | 4.0.2.A.0.42 | ECO | Oct 7, 2011 |
| A | 4.0.1.A.0.283 | ECO | Sep 16, 2011 |
| A | 4.0.1.A.0.266 | ECO | Sep 6, 2011 |
| A | 4.0.A.2.377 | ECO | Sep 2, 2011 |
| A | 4.0.A.2.371 | ECO | Aug 24, 2011 |
| A | 4.0.A.2.368 | ECO | Aug 4, 2011 |
| A | 4.0.A.2.364 | ECO | Aug 4, 2011 |
| A | 4.0.A.2.362 | Variant | Aug 4, 2011 |
the difference seems to be on a regional network connectivity bugs
you got it all wrong, the 4.0.4 update is out but you need to check your SI number, not your build number
http://talk.sonymobile.com/message/199353#199353
http://talk.sonymobile.com/message/199352#199352
before you update to ICS you should check this app first and see if you are ok with the lag
http://talk.sonymobile.com/message/164329#164329
whenever you are ready to update use SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
once you get ICS check this out
Xperia S Music App 4.0.4 leaked, does it work with your Xperia?
http://talk.sonymobile.com/thread/38259
ok thank you for your explanation.
but, i got all these information from here
http://www.wotanserver.com/en/sony-ericsson/se/xperia-mini-st15/4-1-b-0-431/language-download
you can see on the right side, there is a list about available firmwares.
can you explain that too....
thank you uliwooly.
one more question.
is there any possibilities that my phone Xperia Mini (ST15) wouldn't get the ICS upgrade.?
owh my SI 1248-7626. i'm from Indonesia.
thank you before.
you will get it, this is an official answer
http://talk.sonymobile.com/message/211536#211536
When we added this important note to the bottom of our blogpost, we answered your question: *The availability and scheduling of this software upgrade and specific models upgradeable to Android 4.0 will vary by market and carrier requirements
Your carrier has the ability to approve or reject the update (any update) for any device. It is very like ICS will arrive in all COUNTRIES, but considering each country has multiple carriers, it might not come to every device.
In the end, it is very likely you will get ICS, but we cannot confirm it.
i can update my phone manual ST15i, with my build number 4.0.2.A.0.62 ?
i'm from indonesia.
yes you can, make sure to make a backup of your firmware
