A red colour border is being seen while moving between the apps or to new pages. Its more like a flash. Like some virus problem. I then updated the mcafee anitvirus and restarted the mobile. But the problem persists. What would be the casue? How to rectify?
uninstall mcafee, you don't need it, go to settings > developer options is this on or off? if its on turn it off, restart your phone and see if the problem is gone
btw there are NO virus on Android
you can backup and repair your phone
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Thanks a lot man. It worked. Problem solved now.
anytime
McAfee lol
