hello my phone is live with walkman(ics)
i have a problem
i have some hd clip but they are doesn't play in my phone
they format were mkv
i convert they to mp4 but my phone doesn't play them
this is my way to convert and my app is Xmedia recode
is this have a problem???
my phone is show movie with this icon
what can i do??:smileyconfused:
HELP MEEEE:smileycry:
you can change it's format to mpeg using "FormatFactory" or you can download a video player like Mobo Player
unrelated topic, if you have some time please check this thread
transfer it with media go
With this way they are playing????
did you try my suggestions?
http://mediago.sony.com/enu/features You can also use Media Go to transfer videos from PC to phone (and vice-versa), as this application will automatically encode them into format (s) playable on your phone.
Thanks for your help:smileywink:
No worries.
