I need help please my phone is totally dead i cant turn it on after i flash a kernel,i cant even connect itin fastboot mode what i can do????
Try any of the following to see if your device shows any sign of being alive.
Do 2-3 times.
Press and hold the power button + Volume Up button for
5 seconds > ( 1 Vibration ) Force restart
10 Seconds > ( 3 Vibrations ) Force shutdown
If LED turns on or your phone vibrates, then force shutdown your phone and then use flashtool
Flash a stock firmware from here
it cant turned on and the computer and the falshtool cant recognize it
Do 2-3 times.
