It is almost two months that I have this device and I have never seen the network "3G"! the mobile phone is always with "h" and Internet goes slowly (not to speak of when she is with "and"!).
How do I fix this?
Have you seen it too?
Thanks in advance
If you see the H (HSPA) icon you are are in fact on a WCDMA (3G) network.
Which data protocol that's supported by the network differs from operator to operator but normally you'll get the HSPA protocol for Internet access while connected to a WCDMA network.
So if you see the H icon you're having connection to the fastest protocol available in your 3G network. For more information about download/ upload speed I suggest that you contact your network operator.
thanks a lot
