I just update my Xperia S to Jelly Bean, the phone work fine but I can´t found the 3D Swap option into camara app. Where is it ?
Now I can´t see my old 3d Swap Photos in my 3D TV (I could do it before)
For some reason this feature is removed in Jelly Bean. I seek the answer too but without any success so far
if you have a 3D picure just open the album app > look for the picture > tap the picture > you should be able to see the 3D icon
It's a very wrong decision. I bougth a sony mobile because I like 3D and Photo. And sony had the best mix solution. (Not real 3D but it works).
Now I only have a half phone.
I was waiting like a year for the update for this ?
I hope don't find any other wrooong sony decision.
Update is to add new futures or fix bugs. Don't to remove futures and add bugs!!!!!
I can't see the 3D Icon in my old 3D pictures and when I display the photos into the TV the 3D images never be detected.
I'll double check on my xperia s
I stand corrected, it is gone
Well, roshko1991 your answer is correct, but doesn't help me.
One of the many exciting features Sony blessed us with with the JB update was: taking off the 3D panorama sweep function off the camera + fully Lagging HD video recording added + PURPLE tinted pictures when taking pictures at night time (unless you don't modify a few default camera settings, that is)!!
Welcome to Jelly Bean on the SXS, my friend!
This may help:
I know it's sad but it is the only way to have fully functional Xperia S for now (maybe even forever)
This nice topic will guide you:
http://talk.sonymobile.com/thread/41609?start=0&tstart=0
Be careful !
