does mini pro hav a gorilla glass...??? does it hav the exmor r sensor..???
Hi Pravi,
No, the Xperia™ mini pro does not have a Gorilla glass nor does it have Exmor™ for mobile.
fine den.. i'm frm india.. do yu knw wen d updates fr mini pro wil b hittin d shelves here...???
The update is expected to start throughout the end of this month and the beginning of next month.
r u sure mini pro doesn't have exmor, for ur attention plz, look at this pic,
this was posted on a review site that was in the may month before the releas of mini pro, i think. see the specs, is this for mini pro(sk17i) or any other model?.
could u point-out the exmor logo on the right down corner of the specs list.
and what's ur opinion about this xxxxx-seanswers.
is it possible for Sony Ericsson to do a side to side test with the current digitizer and gorilla class, testing strength, how scratch resistant are, etc?
The information in this picture is incorrect. It may have been printed early in the forum development.
one of yur support videos on youtube says it has exmor r sensor..
