Does anyone have any idea where I can get my hands on this? or on whichever one that was the final release? but also the one that came with the device?
Check the XDA forum I know I've posted that back in 2010-2011
/t5/Software-Updates/Updated-2-3-3-for-both-x10i-and-x10a-ALL-KITS/m-p/124302#M1955
thanks
hey, have you tried using the mini as a whatsapp walkie talkie recently? i think they patched the old version, so it wont work now...
this is why i'm checking... haven't used it for a year
