I try auto rotate option and factory reset is also done.., but same problem auto rotation is not working.. I am facing this problem from last one week.., before that it works fine..., help me out
Settings > about phone > diagnostics > test > test everything and report the results.
I am not able to find diagnostic ->test and all in my phone.. Mine is xperia c2004.., help me out
Try service menu instead
/t5/Xperia-arc-Xperia-arc-S/Service-Menu/td-p/103180
Open the Dialer and enter this
*#*#7378423#*#*
I tried that last twodays back only.., the entire phone rest but the issue was not solved.., any some other idea???
