I recently bought Xperia M Dual, and it does not have Developer Tools option. Even a cheap smartphone have that option.
Is it just my mobile problem or there is no Developer Tools option in M Dual.? How to do USB debugging?
"Android 4.2 and higher, the Developer options screen is hidden by default. To make it available, go to Settings > About phone and tap Build number seven times. Return to the previous screen to find Developer options." - Found at:
it works
thanks
This is exactly reason why Developer Option was hidden.
If you do not know what to do with those options, it is better not to unhide them.
BTW, if you want to hide them again go to Settings-Apps-All-Settings-Clear Data
I think you should be reading more about SDK, and this Forum is not dedicated to solving Developers issues.
Go to XDA-Developers for more information
Regards
PS. Hope you understand that my comment is not personal.
Thanks for help
