Initial error
An error occurred while preparing to update your device. No changes were made on your device.
Please try again later. If the problem persists, contact Sony support.
Error code: uestartnomoreports
L_2384
Hi ajiantorooo,
Welcome to the community,
Sorry to hear about the update failure. You could try restarting the PC and running through the process again, it sounds like the PC may be interrupting the connection to the phone at some stage, however, a restart may very well help resolve that.
Let me know how you get on.
Hi @shaifur1547,
Does it boot at all? If it boots, simply try updating it using Xperia Companion. If you can't boot it but are presented with a "Software update failed" message, then I can only advice that you try to perform a software repair using Xperia Companion.
Hello.
I try to use software repair to reinstall the device software in my c2305 phone.
But, after this
I get an error UEUpdateFailed UE_2005
@shaifur1547 I had linked a guide on how to repair the software in my post, @alexdon wrote a great guide which you can find here:
http://talk.sonymobile.com/t5/FAQ/How-to-perform-a-software-repair-with-Xperia-Companion/m-p/1103057
@dembo1972 Try restarting your computer and then restart the process, does that help? Should it persists, try reinstalling Xperia Companion and make sure that Xperia Companion has access to the Internet (not blocked by your system).
Hi everyone,
I have tried to update my M4 Aqua Dual (E2312) twice using the Xperia Companion but I always get UEGetPhoneInfoFailure
UE_1200. Can anyone help.
Thanks in advance.
Could you test a different computer? do you have the latest JAVA ?
Thanks uliwooly for the reply,
I will try your way first. After that, I will update on my attempt to update my phone.
Thanks again.
I've had the same problem just a moment ago while i tried to update the android through the sony mobile application and fix that by:
1- restrting my computer
2- disabling my antivirus
3-start the sony mobile application
4- start the update
and that went just fine.
the message points to a connection error with the update server so that means something blocking the application.
do my steps and let me know.
gotta install the update after i just finished downloading it.
