Hello,
Lately I´ve had problems with my M5 screen, mostly the display has become less sensitive and sometimes the screen flickers or shuts down as if I have just locked it (which I haven't). Today the screen was just as ever with this poorly sensitive display and so on, but jusy about a hour ago it looks like it was a TV screen with lots of interference, it seems like I can open the apps and the phone can connect to the WiFi but the screen remains the same: half home screen half interference. What can I do?
That seems to be a hardware issue and it'll be wise to get it inspected by your Local support
You could also attempt to repair the phone with XC and see if that solves the problem
Alternatives on How to backup Xperias
Same thing what happend to my xperia m5. the display flickering, freeze and can be shut down only by force shut down. however, in my case when the battery is 15% and below its works normally and when it charged to 16% and up things goes wrong.
Ive tried to use hard reset, xperia companion repair, and safe mode but still nothing good happened.
thank you.
