I think it's hardware related but to narrow it down repair the phone with PCC if that doesn't work then contact your Local support
Bridge (for Mac)
Alternatives on How to backup Xperias
Hi @Jedthered
Welcome to the community
I would do as @uliwoolysuggests and check to see if this is a software issue using the Software repair process.
But if it has failed one of the Xperia Diagnostic tests it is more likely to be a hardware issue with the device, so you may be best to have a chat with your contact your Local support team as it will need to be serviced.
