Hi. I cannot enter my pin number to access the phone. There is a "yellow box" around the information on the screen with voice commands for every button i push. i tried restarting,also tried putting in sim and puk numbers........ Can someone help please....
Hi @Warren1,
It sounds like you may have enabled TalkBack on your phone.
You should be able to disable it if you follow the instructions found here (follow the ones for Android 5.0 or 5.1):
http://support.sonymobile.com/global-en/xperiam4aqua/kb/023101885505ba55014a443132620076ab/
Hi @Warren1,
Glad to hear that you were able to solve it!
