Could you post a screenshot?
screenshot = press and hold power & volume down for 1-2 seconds.
Either post the screenshot here or upload it to box or dropbox
Hi Sfiso,
Welcome to the community,
This may be a Developer options function, although I do not think it would action in Safemode, I still suggest checking.
Menu > settings > Developer Options > Turn everything off.
If that does not help, then you may be looking at a hardware or software issue.
Let us know how you get on.
My Sony Xperia M4 Aqua dual has the same problem since this morning. No idea what happened, but I get vertical lines. The phone was bought in India in February and am currently in Italy. I do have a global warranty. Can anyone guide me where I can get this sorted please? Thanks
