Try SUS and if that doesn't work, try a different PC
i am shashi kumar i took a sony xperia m dual c2004 before 1 month back ,
it was superly working but before two days onwords facing problem ,
i'm using tata docomo sim in slot 1and aircel sim in slot 2 ,before 2 days back i change the sim exchange in to slot1 aricel and slot 2 tatadcomo and now the problem is i replace th sim in tata docomo sim in slot 1and aircel sim in slot 2 now its not showing sim 1, it showing only sim2 wat is the problem plzzzzzzzzz give me solution to this
