I went for a walk last night and pull phone out of pocket and must of set off some tutorial mode or something .
Anyway its completely messed up the phone and im struggling to use it effectively .
How do i get out of it ??
So i dont think im in demo mode .
i managed to do the number trick , after learning the press to select then double tap .
But it came up as activate demo mode not de activate .
So when i select anything a green line borders the selection and you need to tap to select you get a lady voice tell you what you have selected you then tap twice to activate that selection .
but i cannot or have not worked out how to scroll up and down in settings when i do finally get there .
Wow that was hard work ,
It was talk back thing you have to scroll with 4 finger tips or full hand for some reason .
It off now so , excellent
thanks for all the help .
I'm glad to hear that it's now working!
