Hi, I just want to ask you guys if any of you is using the "themeable analog clock"...
when I select this option, on the lockscreen it returns back to the digital clock or the sony clock (whichever you are using before selecting the themeable clock). I wonder how can I use this, I searched the market and nothing there (the one for this, not the live wallpaper on lockscreen). I just wanted to use the analog clock on my lockscreen, BUT NOT the default analog clock of sony (the shape is ugly).
anyone?
The Themeable Analog Clock is a feature which was intended to make it possible to personalize the clock in the Xperia M4 Aqua. However, this feature has not been integrated correctly and will be removed in the next quality release, planned to be released in the end of this quarter, Q4 2015.
Could you please send me your details in a PM, and I will forward to see if I can get further information.
Make a relevant topic and include the following.
Name:
Phone nr:
E-mail:
Country:
Operator:
Product(s):
IMEI nr:
Build number:
@Hampus wrote:Hi,
Name:
Phone nr:
E-mail:
Country:
Operator:
Product(s):
IMEI nr:
Build number:
im sorry, is this necessary? is this needed to answer my question regarding the THEMEABLE ANALOG CLOCK?
I'm afraid I do not have information why this setting cannot be kept when choosing it and therefore, I need to forward it to get further information.
@Hampus wrote:I'm afraid I do not have information why this setting cannot be kept when choosing it and therefore, I need to forward it to get further information.
to make my query short, what is the purpose of this "THEMEABLE ANALOG CLOCK"? or rather, how does this themeable analog clock looked like when activated? (at the moment, im not after why is it not kept when chosen.)
is somebody here using/used it? if yes, how does it looked like?
below are the only details i can provide:
model: xperia m4 aqua dual (16gb, E2333)
version: 5.0
build: 24.1.B.2.147
Honestly, it is the first time I see it so I'm not sure if it should be there. But I will forward this internally.
@Hampus wrote:Honestly, it is the first time I see it so I'm not sure if it should be there. But I will forward this internally.
really? also, in case you will ask, i don't have any theme launcher or whatsoever. im only using sony themes and other themes that are downloadable and can be installed directly without a theme launcher.
by factory default i know it is not there. then the first update(26.1.B.2.102) came, that "themeable analog clock" appears, and still there up to now (26.1.B.2.147).
can I ask a favor for those who has a E2333 model to check their devices if you have this option? it would be very much appreciated if someone also did use of it. thanks!
this watch appears to my E2363 too, but can not be selected
anyone?
