Hi, I have an Xperia M4 ... The problem is that the status bar does not go down ... I just rebooted it and it's like I did not do anything ...
Hola tengo un Xperia M4... El problema es q no desciende la barra de estados... Solamente lo he reiniciado y es como si no le hiciera nada...
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Does your phone has a protective film, glass or case?
No
Translation via Google Translate:
Did not pass the test
No paso la prueba
