I tried every way but dear friends,
I am not able to forward the message.
Attached are the photos.
you could see that there are no options to select for forwarding.
Please advise.
Regards
Arshi
I'm not able to see the images and I think It will take time to display.
Try pressing and holding your fingure on the text message body and You should get forward option.
