Question;
Does my M2 have reliable (pr any) temperature sensors?
Csn it tell me the correct room tempreture?
the temperature sensor it has is only for the internal measurement of the components. you can check this out by downloading CPU-Z app on google play store. the sensor is not intended to measure environmental temperature
Fair enough. So those Temprature apps are useless then?
