Hello,
I have a M4 Aqua.
I have Stamina mode and My Experia (phone locater) mode enabled together.
Since Stamina mode disables network connections when the screen is off, My Experia mode will not work and the phone cannot be located if lost.
Under the Stamina mode menu, there is an option to allow certain apps to stay connected. I do not see My Experia in this list. Is there anyway to get My Experia to work when Stamina mode is enabled?
Thanks.
@billford Are you running 5.1.1? If you go to add aplications, you should see all others tab. There, my xperia is available.
The M4 Aqua is running the latest 5.0
I rechecked and found there is an "others" tab. I did not see that before and My Experia was in it.
Thank you!
