Hi guys.
I´m having a little problem with my Xperia m2.
I plug it to charge, and the led light reconizes it like it should, but still when I try to turn it on, it appears a no battery screen, like the phone is without charge.
Anyone had this problem before?
Thanks people and sorry about my bad english
you might have to repair the phone with PCC
software repair using PC Companion
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Thanks man, but i actually already fix it.
But thanks for the help any way! :smileysmileythumbsup:
Hi there Jack, thank you.
I fix it by holding up de power buttom and the volume up button, but it only charged about 50%. Now after I used the phone and the phone is around 30% it wont even charge again.
Tommorow i wil try to repair it using PCC as uliwooly said. Hope it works
I do suggest using the Software repair as provided by @uliwooly this does sound more software related than hardware. I wish you luck
No can do, it says i dont have a internet connection so i can not try to repair the software, still it was browsing the net when it said that... 😕 I´ll try again later.
It´s charging again, but still does not pass the 51% of charge
Hi Johnnny,
If PC Companion is not connecting to the Internet, then it may be behind a firewall, I suggest adding PCCompanion.exe to your firewall exceptions list.
Thanks yout for the advice. I already got PCC working, but now the phone wont charge again, and I need to have at least 50% battery. Lights indicates that the phone is charging, but it it allways show the no baterry sign.
Maybe it need a new battery? I don´t know, cause when it was charged, it lasted 2 days without charge.
Starting to get a little frustrated with it...
