I bought a Sony xperia M dual c2005 from Oman after using 2 days it's battery draining so fast like watch time. What is the problem. Hardware or software? I checked this phone hardware by this code *#*#7378423#*#*. No hardware found. Is there any hidden hardware problem. Or software problem....? Plz give me a best solution.
Boot your phone in safe mode,see if the same occurs:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
Thanks to suggest me..I will try like this. I reseted my phone last day but no change same promlem. There are no third party application. Battery run out in stand by mode. Most of charge kill screen. Here giving screenshot below
Dear, In safe mode battery give little more back up than normal mode but not satisfied. This phone screen is killing to much battery without more use.M i right? Here given screenshot below:
IF you do not use the phone too much,you will see the screen first because when you turn on the display,it will be the first battery eater.I think you have a good battery life.
I can't move apps to Sd card. Plz suggest how to move apps internal storage to SD card? Or Fix this problem with new update. Thanks
Thank you, my battery draing problem gone after boot safe mode. Now i m using in normal mode. I think this prob gone when i charged my phone countinuously 4/5 hours
You cannot move apps to SD,that is not possible unfortunately.I am glad to hear it works fine now.
no way to move apps to sd card? is it possible to move apps to sd card by Android SDK....Plz help me....
You need to root the phone to be able to move apps to SD.
