There might be some files still left from the app you downloaded. You could use a file explorer or connect the phone to a computer to check and delete manually.
Well, if you want to clean the phone you can use the function under Backup and restore in the settings menu.
Ahhh hmm ehhh hi again °-° heres my problem my phone hand 2gb used ONLY wen i did the lollipop it went to 3.4gb used it wasend a problem for a while but now i realy beed them what should i do ?
Hi there,
First of all, please read this topic regarding memory in Android: http://talk.sonymobile.com/t5/FAQ/Memory-in-Android-devices/m-p/348064#U348064
