I was updating to the latest version of Kitkat (18.3.1.C.0.21) and, after phone restarted the android guy with a red exclamation point appeared, everytime I restarted the phone, that happened.
So, I got the latest ftf file and flashed it using Flashtool. Operation completed with success, however, phone doesn't power on, nothing happens.
No vibration, no SONY logo, nothing.
Tried booting in flash mode but no LED blinking.
Windows does detect a device named SOMC Flash Mode but, that's it
PC Companion can't detect the phone but Flashtool kinda sees it:
15/012/2015 00:12:50 - INFO - Device connected with USB debugging off
15/012/2015 00:12:50 - INFO - For 2011 devices line, be sure you are not in MTP mode
However, that's as far as it goes.
I don't know what's wrong, from a lot of searching, device might be in EDL mode (?)
Anyway, I'll be thankful if you guys help me out.
Bootloader is locked and never touched, if that helps.
Anytime
friend , I would like to know how solucionaste the problem because it happens to me the same with my Sony Xperia E1 and not to do. We greatly appreciate it !!
Do we have aby update?
i am facing this problem since more then a year and in my country there is no Sony service store orignal one...
no am currently hopeless at the moment wanna fix this issue my self...
SOMC FLASH ISSUE firstly it shows me fastboot S1 one..then i install xperia z2 driver and showed me SOMC all fine...
Now the issue is i cant able to flash my phone its just stuck on SONY logo....
flashtool i have tired didnt worked..
Xperia companion it just cudnt bypass that Power and vol down part.,..ughhhh could some one just help me out what is the main issue about it.. people said its faulty motherboard..i stilll dont belive it... if thats the issue it wont probably bootup phone or even shows sony logo.... i know its some kinda software problem i wanna fix somehow
Hello ,
Same Issue with my mobile...Are you get any solution for that....
My mobile starts but sometime it will restart again again ... I wan flash it but stuck on
01/032/2017 11:32:37 - INFO - Please connect your device into flashmode.
01/032/2017 11:32:39 - INFO - Opening device for R/W
01/032/2017 11:32:41 - INFO - Reading device information
No further proceed
I am doing all kind Procedures But didn't succesued.
If you get any Solution..Please reply asap..!! THanks
necesito repararb mi sony xperia
need to fix my xperia
GT
