Hi @Daniel64, welcome to our community!
Is it the counter that you can find in the service menu that reads "0" next to Network lock? If that is the case, you will need to get in touch with your Local support team and they will assist you further.
If you need a code to unlock the network lock, you will need to get in touch with your operator and they will provide a code for you.
I hope that helps and I'm sorry if I misunderstood your question!
